Solved
Amd build recomendations please help
I was recomended to go with Intel build, heres my setup now.....
memory http://www.newegg.com/Product/Product.aspx?Item=N82E16820231314
GPU http://www.newegg.com/Product/Product.aspx?Item=N82E16814127578
motherboard http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=93425&CatId=6978&inbeta=Y
PSU http://www.newegg.com/Product/Product.aspx?Item=N82E16817182072
CPU http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072
case http://www.newegg.com/Product/Product.aspx?Item=N82E16811119197&nm_mc=OTC-Froogle&cm_mmc=OTC-Froogle-_-Cases+%28Computer+Cases+-+ATX+Form%29-_-Cooler+Master-_-11119197
ssd http://www.tigerdirect.com/applications/searchtools/item-details.asp?EdpNo=365474&SRCCODE=GOOGLEBASE&cm_mmc_o=VRqCjC7BBTkwCjCECjCE
$140/110-MSI P67A-GD53 B3 Intel P67 Motherboard - ATX, Socket H2 (LGA1155), Intel P67 Express, DDR3 2133MHz (O.C.), SATA 6.0 Gb/s, Gigabit LAN, CrossFire/SLI Ready, USB 3.0
$265-MSI N560GTX-Ti Hawk GeForce GTX 560 Ti (Fermi) 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
$215-Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) 4 x 256KB L2 Cache 6MB L3 Cache LGA 1155 95W Quad-Core Desktop Processor BX80623I52500K
$120-OCZ Vertex Series OCZSSD2-1VTX30GXXX 2.5" 30GB SATA II MLC Internal Solid State Drive (SSD)
$45-G.SKILL Sniper Low Voltage Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBSR2
$90-COOLER MASTER HAF 922 RC-922M-KKN1-GP Black Steel + Plastic and Mesh Bezel ATX Mid Tower Computer Case
$126/90-XFX Core Edition PRO850W (P1-850S-NLB9) 850W ATX12V / EPS12V SLI Certified CrossFire Ready 80 PLUS BRONZE Certified Active PFC Power Supply
935 after rebate
1005 before rebate
ME>>>:) After making a perfect xmas sandy bridge, lol
About the 60gb ssd im going to use that for speed not storage i have a 320gb sata for storage.
all help and opinions are welcome, thanks.
ok edited the this as of 7:47pm 11/13/11
Please Post links, THANK YOU Also if u havent noticed WILL select best answer if I like your Post, so If you benifit from it dont be lazy...
5 answers Last reply Best Answer
More about build recomendations help
  1. Best answer
    Definitely better than the last one but you really need to read this article about PSUs, especially the last two pages:
    http://www.tomshardware.com/reviews/power-supply-psu-review,2916.html
    But don't go with a two-egg rated SSD though - you'll wind up replacing that one a lot. Spend a few extra bucks and get a Crucial M4 - it's one of the best SSDs on the market.
  2. Agree, the SSD is crap. Read some of the reviews. They all say it worked rarely and did strange things to Windows.
    Yeah seriously. If you're gonna drop $1,000 on a computer and you don't have the money to replace anything if it goes bad, don't say we didn't warn you. :non:
    DO YOUR RESEARCH!!! Read reviews, read product recommendations, even check Consumer Reports, I don't care. Just don't buy crappy hardware for a system that you want to last just to buy it. Make sure you read through everything and check everywhere to make sure you're getting the best bang for your buck. The absolute worst thing you can do is pick crappy hardware because it's cheap and you want to get something that's more expensive because its' "faster". Really spend the time - pick out the right parts, and put together a good system. I will repeat: don't buy just to buy. Really do your research if you're going to spend $1K on a system.
  4. Best answer selected by almightynsx.
New Build Systems Product
