New build Help need some parts 800$
Approximate Purchase Date: ASAP - my pc just died :@
Budget Range: 800$ - 1000$
System Usage from Most to Least Important: Gaming - multitasking - movies - web browsing
Parts Not Required: Mouse, Keyboard, Headset, Case, Monitor, GPU (HD 5830)
Preferred Website(s) for Parts: dont care.. as long is in USA or Canada
Country of Origin: Canada
Parts Preferences: I7 2600k, Motherboard ASUS or Gigabyte, 8gb or more RAM, Power supply 700 or 750 i tinhk it would be enough, and fan cooler, Hard drive and im thinkg about the SSD or whatevfefr u guys call it
Overclocking: Maybe
SLI or Crossfire: Maybe
Monitor Resolution: i have 3 monitors 1440x900
Additional Comments: okey mi PC just died wont boot i tried everything... keep reboting and ***.... so im done and i was planning to buy a new pc anyways...
My question is my Case is a Antec 900 http://www.bjorn3d.com/Material/revimages/case/antec_900/900_q.jpg , so i want something that will fit in there... if i have to change case i might do it but its not in my plan... i want a nice mobo for future upgrades and with a little bet of space... and haveing Bluethoot is nice or jsut a waste or space?
6 answers Last reply
More about build parts
  1. Check out my $850 build in my siggy right here:
    http://www.squidoo.com/electronicandmore
    It'll give you a lot of performance for the buck.
    The i7 isn't needed, the 2600K performs only about 1-2% better than the 2500K in Gaming so the extra $100 is defiantly not worth it for what you're doing.
    As for the Cooler I suggest one of these two.
    Hyper 212+ http://www.amazon.com/Cooler-Master-Hyper-Sleeve-RR-B10-212P-G1/dp/B002G1YPH0%3FSubscriptionId%3D19BAZMZQFZJ6G2QYGCG2%26tag%3Dsquid1240995-20%26linkCode%3Dxm2%26camp%3D2025%26creative%3D165953%26creativeASIN%3DB002G1YPH0
    or
    Hyper 212 Evo http://www.newegg.com/Product/Product.aspx?Item=N82E16835103099&Tpk=Hyper%20212%20Evo
    The 212+ is fairly old but offers similar performance to the Corsair H50/H70, the Hyper 212 Evo is the revised version but better by a bit.
    http://www.hardwaresecrets.com/article/Cooler-Master-Hyper-212-EVO-CPU-Cooler-Review/1407/6
    I suggest getting the new card, 3x1440x900 is a lot of resolution for a single 5830 to handle. Specially since the 5830 is really only equivalent to something between a 6770 and 6790. IF you plan to game on JUST one monitor then the 5830 would be fine. But if not, a new card is recommended. I suggest the 6950 2GB like in my build guide.
  2. i use normaly 1 monitor for gaming but at the same time im webbrowings, video and more... so i want my pc to be able to be as fast as she can be...
  3. Well if that is the case, just stick with your 5830 if when you're gaming with only your 5830. It'll handle gaming well at just 1440x900. If you are just browsing and watching/editing video etc. (Just not gaming) with 3 monitors the 5830 would be sufficient.
    Anyways, just check out the $850 I had up their just no need for that GPU and save on the PSU since you don't need that much power, specially with a 5830. Get this one instead.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817371044
    This'll provide enough power if you ever Crossfire 5830's but give you good savings on cost.
  4. i want a 750 cause in the future i might crossfire... so my main concern are processor mobo and ram for now... i can buy a new gpu later...
    and of course i will eyefinity once in a while xD
  5. Well if you ever CF the 5830's you'll only need a 650w at most. The other parts I listed here in the $850 build section: http://www.squidoo.com/electronicandmore
  6. anybody else have any suggestions?
New Build Systems Product
