As rock h61m ps2 (help)
I am on a budget pc. For gamimg and other stuff
I am planning to buy an i5 3570k
Wld the as rock h61m ps2 be right choice?
It .says it support k series cpu though it is h61. Also it has a pci 3.0
Is it a good bargain i dont need sata 3 or usb3 for now.
1 answer Last reply
More about rock h61m help
  1. No. Get a board with the H77 or B75 chipset; older h61 boards often require a bios flash with sandy bridge cpus before ivy bridge cpus such as the 3570k will run. You have a fine cpu capable of overclocking. I would look for a low end z77 chipset board to take full advantage of it.
ASRock PlayStation Intel i5 Motherboards
