Building my first PC was a nerve racking experience. I about died when I realized how much force and had to use on the lever to get my i5 2500k cpu down. The crackling noises didnt help either.
Anyways, first boot up was successful as well as 2nd boot once everything was in the case. I installed windows and put all my drivers in. I left the computer running for about 45 minutes with no problems.
My only concern is the thermal paste. I used the hyper 212+ fan and it wasnt easy to install. I put 3 small lines of paste on the heatsink between the copper cores. I put the smallest dab in the middle and put it on. The fan moved around a bit because I had such a hard time with the harness on the fan. Everything got screwed down tight.
Whats the best way to test to see if the thermal paste was applied correctly? What should I expect if it wasnt done correctly and can any major damage be done? The idle temp was 29 degrees.
