Help me setup Raid on ASrock Z77 Extreme4 please
Having a hard time understanding some of this.
I am UPGRADING mobo and chip only. Installed mobo, i5-3570 (no k because I ordered incorrectly like an idiot and didnt notice) fine.
Plugged in my SSD and reinstalled Win 7.
Pretty sure I have all the drivers updated. Not positive, but fairly sure.
My SSD is in SATA port 2_4
DVD ROM in SATA port 3_1
Now I have to plug in my two WD Caviar Black 650gb HDD's and set up raid. I don't care if raid 0 or raid 1, your suggestions are fine.
Questions:
1. Which ports to install the HDD's?
2. I presume I'll have to reformat and erase everything on them? *I have ext HDD with backups and files to transfer once I have programs installed.
3. Suggestions on use bios or the intel utility to setup raid?
Thanks for your guidance!
More about : setup raid asrock z77 extreme4
raid 0 makes your drives running as one meaning they will give you faster speeds but if one drive fails you loose all of the data
raid 1 makes a mirror copy of your drive so you get no speed improvement but redundancy if one drive fails you always have the second drive with all of your data
ok so firt you have to go to bios and change sata mode from ahci to RAID
from there save and restart
you will be prompted with a new window (your raid configuration)
press ctrl+i or ctrl+f (it will tell you what to press to enter the raid configuration utility)
from there you will set up your raid
1. it doesnt matter which ports just make sure they are both in the same sata speed port (to check which sata port gives you 3gb or 6gb per sec look into your motherboards manual)
2. you're right when creating raid volume (either 0 or 1) it will prompt you the hard drives will be formatted
Hey thanks for responding Alvine.
I'm sitting here with coffee in hand impatiently waiting for such responses to continue my adventure.
Couple quick questions: *(I've not gone back to bios yet as I post this)
Would my process now be:
1. shut down system
2. plug in hdd's in proper ports
3. go into bios (or let reformat start, whichever happens first) and set ONLY the HDD's to raid, save and restart.
4. go into raid config and set up raid.
Do I have it right?
Thanks!
1. shut down system
Do I have it right?
Thanks!
yessir you got it right. just make sure to backup your data from the drives if you have anything important. the raid configuration utility will warn you about the format after you have selected the two drives you want to configure and which raid type you want implement
to make it easier on yourself have the ssd on separate sata controller as the motheboard comes with two..one controller for sata 3gb and one for 6gb...have the ssd on 6gb sata and the two drives on sata 3gb ports...if you're confused as to which sata port is which read up on the motherboard manual..im 99% sure it will outline raid configuration process too
Related ressources
- How to setup raid 1 on asrock Z77 extreme4 - Forum
- NEED HELP ! asrock z77 extreme4 won't boot from SSD - Forum
- ASRock z77 Extreme4 - Won't recognize drive on OS install - Forum
- What GPU I should get for gaming? MB Asrock z77 extreme4 & I5 3570K - Forum
- Asrock Z77 extreme4 Please help ! - Forum
Ok, I just don't know what to think or say.
I had to switch ports on the ssd to sata 3 as I had it in sata 2.
Plugged in the HDD's and did as instructed, but was not offered on restart anywhere to setup raid config. Yet when it showed the drives in the black screen just before Win7 I quickly saw it recognized my ssd and HDD's but it was so fast I couldnt see if it said raid stripe or not.
So windows opens, I get a popup to restart, do so, and when windows comes back I open computer and my 2 x 650gb hdd's are Disk F with 1.08 TB free of 1.16!
I opened the disk and everything from my old system was there. So it looks like it worked even better than expected.
No reformat of hdd's. Interesting indeed.
i need some help too i have the same z77 asrock extreme 4 3570k i got my drives in port 1 and port A1 sata 3 what do i need since we got same mobo im confuse how it works do i download anything floppy etc or what? i 1 750 hydrid drive with stuff and the other drive is New samething 750 hydrid just need step by step how to set it up or what to do since we got same mobo please guide me thank you
Ok, I can't be 100% positive on this, but here's my thought.
You said OS was installed on one hard drive and not the other. I think that's where your problem is. But I could be wrong.
I have not installed an OS on one drive and then tried to raid with a 2nd drive. Again, not familiar with that. But I think raid is (if installing os on those drives) supposed to have os on both the drives.
On my computer, I installed the OS on to my ssd. THEN, I plugged in the HDD's and set up raid. Again, after the os was installed on my ssd.
Here's two pics in the bios of what mine looks like.
http://imageshack.us/g/651/p1020008y.jpg/
Again, I'm in totally unfamiliar territory, as I have only done this with three drives, one being the ssd which held the os.
I think, you need to reformat and clean the hdd with the os. Then set raid, then install os and it will properly install on both drives. But that's just my logical thought process.
I am having this exact same issue. I have 2 brand new SSDs and I want to set them up in Raid 0 before I install windows.
EDIT: As per the manual - "Please be noted that SATA3_A0 and SATA3_A1 do not support RAID function. If you want to use RAID function on SATA3 connectors, please use
SATA3_0 and SATA3_1 connectors."
Here's where you want to plug them in:
I re-install both already lol my old hydrid had problems installing sound blaster z and had to install new windows on it. Both can be fresh now but that's a downside because hydrid drives the more u use it and longer the faster it is.
By the way big fishy has them in sata 1 and A1 too and his work >.<
http://imageshack.us/photo/my-images/845/photonuc.jpg/
http://imageshack.us/photo/my-images/40/photo1ajsh.jpg/
I want to put it in Raid 0 now what i do
Himea said:
I re-install both already lol my old hydrid had problems installing sound blaster z and had to install new windows on it. Both can be fresh now but that's a downside because hydrid drives the more u use it and longer the faster it is.By the way big fishy has them in sata 1 and A1 too and his work >.<
According to his pictures form earlier his are in the SATA2_4 and _5 spots which should support RAID as well. He also mentioned that he had them in the SATA2 ports and then switched them over to the 3's so I'm not exactly sure where he plugged them in. As for losing all your data, that will always happen if you plan on building an array with the drive you're already using. Building a RAID wipes the drives before it builds it.
Himea said:
http://imageshack.us/photo/my-images/845/photonuc.jpg/http://imageshack.us/photo/my-images/40/photo1ajsh.jpg/
Select the first option to start crating the RAID. You'll be using your 2 drives in RAID 0 so make sure to set it to that with 128k stripe, you can name it whatever. Make sure you also select the correct drives. It will wipe everything and the RAID array will be created.
If you plan on installing Windows on this RAID make sure you have the drivers on a floppy disk or something (Anything should work) just in case the windows installer doesn't see your RAID. Everything else from then on is the same as a regular installation.
Himea said:
when i go into create a Raid 0 and Name it and put 128k then Select Disk it's empty it won't let me o.0?Just to make sure, you have both the drives that you want to RAID plugged in to the ports that I circled in the picture I posted above? And everything in your BIOS is configured in the way that was mentioned earlier in this thread?
http://imageshack.us/photo/my-images/404/photo3zol.jpg/
http://imageshack.us/photo/my-images/534/photo2hiv.jpg/
Both have new OS install or do i need to delete the OS?
Himea said:
Yes they both set up as you saidOk, here's a step by step:
1. At the RAID Setup UI you select the first option "Create Raid Volume"
2. Give it a name (Optional) - Press Enter to move down to "Raid Level"
3. Set to RAID0(Stripe) and press enter - Mine had that already by default.
4. Give it a Strip Size of 128 by pressing the down arrow on the keyboard and then press enter - You can set it to something else, but I prefer 128.
5. Press enter again to accept the given capacity (should be max by default)
6. Press enter once more to begin creating the volume.
7. Press Y to continue.
8. You're all set now...
Now you can install windows if you wish. Creating the RAID will wipe the drives so you'll have to reinstall Windows. It should be seen as 1 disk by the OS now. If it doesn't show up during the windows install then load the drivers from a floppy disk or flash drive as I mentioned earlier. Mine was recognized so I didn't need the driver to install.
Himea said:
i got both Windows install already do i delete windows and do all this steps?Creating the RAID will wipe everything off both drives. Just proceed to install windows as you normally would and if the drives do not show up (Where you choose a drive to install windows to) then you'll want to load the drivers as mentioned earlier.
The files are are: http://www.asrock.com/MB/overview.asp?cat=Download&os=W...
It should be the "SATA RAID Driver". Be sure to unzip the file and put the contents on your flash drive.
Bigfishy said:
Again, I'm in totally unfamiliar territory, as I have only done this with three drives, one being the ssd which held the os.I think, you need to reformat and clean the hdd with the os. Then set raid, then install os and it will properly install on both drives. But that's just my logical thought process.
I have 3 ssd's that I want raid 5 on with/OS. I also have a 2T that I want just as storage. All internal. Asrockz77 extreme4. Help me out would you? Saw some videos about getting a cd or flash drive with the driver. Is this the case, or did you do yours different?
Related ressources:
- ForumASrock Z77 Extreme4 system panel header setup
- ForumAsrock Z77 Extreme4 vs ASUS P8Z77-V LK
- ForumAsrock Z77 Extreme4 HELP !!!!
- ForumAsrock Z77 Extreme4 3TB HDD problem
- ForumASRock z77 extreme4 help !
- ForumGTX 570 not recognized in ASRock Z77 Extreme4
- Forum[ HELP ] OCing i7 3770K on ASRock Z77 Extreme4
- ForumASRock Z77 Extreme4 USB 3.0 ports on back
- ForumASRock vs Gigabyte Z77 ( help me choose)
- ForumOCZ Vertex 4 + Z77 Asrock Extreme4 Compatibility?
- ForumASRock Z77 Extreme4 Recommended Ram?
- ForumExplanation needed for Code 30 in ASRock Z77 Extreme4 Mobo
- ForumAsRock Z77 Extreme4 turning on problems
- ForumGigabyte GA-Z77X-D3h VS the Asrock z77 Extreme4
- ForumP7h57, i5-760 and 2x8gb
- More resources
Read discussions in other Motherboards categories
