Why do motherboards have 24 pins and power supply only 23?
- Will xfx amd radeon hd 7750 gddr5 graphics card require only Tech-Com SSD-PSU-6001 (20 + 4) 24 pin Power Supply 600Watt ATX - Forum
- 20 Pin Power Supply to 24 Pin Motherboard - Forum
- Power supply for Motherboards 20 or 24 pin... - Forum
- Power supply only has 8 pin CPU cable, but the motherboard only has a 4 pin socket? - Forum
- power supply only has 2 4 pins i think i need more but i dont know how. - Forum
- SolvedMy 24 pin connector only has 23 wires Forum
- Power supply is hooked up properly I believe. Both the 8pin CPU and the 24pin are connected along with all the smaller pins fo Forum
- How do I rig power supply to handle both 24-pin and 20 pin motherboard Forum
- 24Pin Power Supply won't latch to motherboard Forum
- 20 Pin Power Supply to 24 Pin Motherboard Forum
- [HELP] Power Supply 24 Pin connector to Motherboard will not budge Forum
- 20 4 pin power supply 24 pin motherboard Forum
- SolvedHelp PC only turns on when 24 pin power connector is pushed Forum
- My motherboard wants an 8 pin connection from the power supply, but only one 4-4 connection from the PSU fits. Is this okay? Forum
- Solvedwhat does "20/24 Pin" mean in re. to Power Supply Unit Forum
- 24 Pin Power Supply Cable to Motherboard Forum
- 24pin power supply into 20pin motherboard Forum
- Power Supply 20 to 24 pin motherboard cables Forum
- 24 pin power supply in 20pin motherboard Forum
- More resources
Read discussions in other Motherboards categories
