T tulsidasji Distinguished Nov 9, 2011 19 0 18,510 Nov 12, 2011 #1 CAN SOMEONE ASSUrE ME THIS IS A GOOD BUILD ESPECCIaLY the PSU http://www.newegg.com/Product/Product.aspx?Item=N82E16817207013
rolli59 Titan Oct 27, 2007 47,790 283 130,890 Nov 12, 2011 #2 Yes it is a good build with a good PSU. Depending on resolution it could though do with a better GPU. Upvote 0 Downvote
T tulsidasji Distinguished Nov 9, 2011 19 0 18,510 Nov 12, 2011 #3 rolli59 : Yes it is a good build with a good PSU. Depending on resolution it could though do with a better GPU. ONE QUESTION DO YOU LIKE XFX PSUS are they reliable Upvote 0 Downvote
rolli59 Titan Oct 27, 2007 47,790 283 130,890 Nov 12, 2011 #4 They have gotten good reviews by respected hardware sites so I would consider buying one. http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story3&reid=225 Upvote 0 Downvote
userngalan Distinguished Oct 7, 2011 92 0 18,660 Nov 12, 2011 #5 btw what is the specification of your system? Upvote 0 Downvote
T tulsidasji Distinguished Nov 9, 2011 19 0 18,510 Nov 12, 2011 #6 userngalan : btw what is the specification of your system? LOOK AT THE PIC Upvote 0 Downvote
T tulsidasji Distinguished Nov 9, 2011 19 0 18,510 Nov 12, 2011 #7 but i havent bough it i keep thinking about what if it comes as DOA it costs a lot on newegg you know the shipping and stuff Upvote 0 Downvote
rolli59 Titan Oct 27, 2007 47,790 283 130,890 Nov 12, 2011 #8 tulsidasji : but i havent bough it i keep thinking about what if it comes as DOA it costs a lot on newegg you know the shipping and stuff It does not matter which one you buy there is always a slim chance that it comes DOA, happens to all of them regardless of manufacturer. Upvote 0 Downvote
Mousemonkey Titan Sep 3, 2006 59,466 17 92,965 Nov 12, 2011 #9 This topic has been moved from the section CPU & Components to section Systems by Mousemonkey Upvote 0 Downvote
