Hi, i need help building a build. I want Gtx570 (gpu) and Intel core i5-2500k (cpu) but i don't know what i should get for the rest of the build. I need help.
I'm going to buy the build from this site http://www.inet.se/
Gtx570 https://www.inet.se/artikel/v100058/evga-geforce-gtx-570-1280mb-hd-soc-battlefield-3-edition
I5-2500k https://www.inet.se/artikel/5309986/intel-core-i5-2500k-3-3ghz
The gtx570 costs 3k and the i5 costs 1.8k, making it total of 4.8k.
My friend recommend this build https://www.inet.se/kundvagn/visa/1094308/overkill
I don't know if it is really worth the money. Is that a good build? Can you build a build that is better and cheaper than this? My budget is 10k-11k. I might buy this build if it is worth it.
