Closed
PC fan > speed controller > powered by 12v adapter
  • Power Supplies
  • Controller
  • Connection
  • Fan Speed
  • Components
Last response: in Components
February 12, 2012 4:30:49 PM
Hello,
I am hoping to connect a couple pc fans to a fan speed controller, and have it powered with a 12v adapter. I am hoping to do this cheaply, like possibly buying off ebay.
Below is a picture of the fans I already bought, but finding the right connections to speed controller has been a real challenge.
Thank you in advance :)
Uploaded with ImageShack.us
More about : fan speed controller powered 12v adapter
a b ) Power supply
February 12, 2012 5:25:41 PM
Hi :)
Umm those fans have only 2 leads...no speed control lead...it wont work...the best you will be able to control is ON or OFF...
All the best Brett :)
Score
February 12, 2012 5:41:55 PM
Thank you for both responses.
@Brett92S@ - Since I need to buy new fans (if I want speed control) what should I look for in purchasing new fans?
Hoping to find some cheap ones on ebay.....:)
Score
Best solution
a c 243 ) Power supply
February 13, 2012 5:12:39 PM
You don't need to buy new fans to have speed control.
Speed control is obtained by raising and lowering the voltage , that's what the fan controller does.
You won't know how fast or slow the fans are going because there's no rpm cable.
February 14, 2012 2:01:30 AM
Best answer selected by skruger.
Score
February 14, 2012 2:02:03 AM
Awesome, thank you for your time :)
Score
a b ) Power supply
February 14, 2012 9:58:50 AM
This topic has been closed by Mousemonkey
Score
