M MarkHentz Distinguished Feb 12, 2012 1 0 18,510 Feb 12, 2012 #1 Hello, I cleaned computor when done seems to run fine but no signal to monitor
mubin Distinguished Jul 29, 2009 1,972 0 20,210 Feb 12, 2012 #2 Hi, welcome to the forum. If you unplug anything for cleaning then tighten those component. May be ram or vga card is loose. For that you maybe get no signal to monitor and check the monitor connection. Upvote 0 Downvote
ashutoshgupta Distinguished Dec 4, 2011 66 0 18,640 Feb 13, 2012 #3 check your signal cable..... Upvote 0 Downvote
