What speed is my ram running at ?
Last response: in Memory
Okay now I've bought two sticks of nice Corsair XMS3 RAM. To be precise " Corsair CMX8GX3M2A2000C9 DDR3 XMS3 8GB "
It says that the RAM sticks should be running at a clock speed of 2000MHz & a 9-10-9-27 latency. Was wondering how I'm actually meant to check if it running at that speed ?
Thanks guys
Thanks guys
More about : speed ram running
Related ressources
- Cant figure out at what speed my RAM is running . - Forum
- How to tell what speed your ram is running at?? - Forum
- Running 1333 rated RAM at 1600 speed ? - Forum
- RAM not running at advertised speed - Forum
- Ram not running at correct speed - Forum
DarkSable said:
Erm... you know that timings are better when they get lower, right? Just checking.He was asking about 2133 @ 7-7-7 which to the best of my knowledge is impossible.
His RAM defaults to 7-7-7 @ 1033 MHz, but when he went up to 2133MHz his timings went up to the 13's.
So I suggested he didn't clock the RAM all the way up, and use the 990FX default of 1866 and try to get tighter timings.
Okay, so his ram is much more towards the norm.
I think what's happening is that your motherboard / CPU simply isn't able to handle faster memory when it comes to something as RAM dependent as web browsing. Try undervolting and underclocking your ram to 1600 MHz or 1033MHz (since you know that last one works.)
Well, I'm not certain either way. How did he perform the memtest pass - was it a single run, or was it multiple tests running at once, repeated three or four times?
Yeah, I think your motherboard and CPU should be able to handle it, but that they aren't performing up to snuff... I do wish there was a detailed software that could be used to test the motherboard functions, though.
Well the typical timings for 1866 are 9-10-9-28, but that's not necessarily what your RAM wants. What happens if you run it at exactly its rated specs? It might just have a problem with the lower latencies, since it was built to run faster. (I'd doubt it since it did well in your friend's computer, but...)
Also, what voltage are you running it at?
Related ressources:
- ForumRam running under 40% at full speed
- ForumIs my ram running at correct default speed ?
- ForumBest setup for running 12gb of high speed RAM .
- ForumWhat speed ram should i get for this processor?
- ForumRAM not running full- speed
- ForumRam wont run at native speed ?
- ForumRAM running at wrong clock speed
- ForumNeed help, I dont think my ram running at the correct speed .
- ForumRAM not running at speed it should be?
- ForumDDR, and DDR2 RAM is running at 3/4 full speed
- ForumHelp updating BIOS
- Forum[Solved] What does it mean that a "PCI-Express 3.0 X16 Slot runs at X8"?
- ForumWhat motherboards have 2 4-pin ATX hook ups
- ForumDeciding on 3 different sets of high speed RAM
- ForumWhat to look for in a motherboard?
- More resources
Read discussions in other Memory categories
