Can I convert an unused SATA power cable to PCI-E for the GPU?
Last response: in Components
- can i turn a sata 2 cable into a pcie 6pin power cable for a gpu? - Forum
- Difference between using PCI/E power cable to connect to GPU v/s peripheral power cables - Forum
- IDE/SATA cable AC Power Converter - Forum
- Can I use the Sata cable to power up my GPU's? - Forum
- Help needed with wiring: PSU PCI-E Cable or Cable which came with GPU? - Forum
- SolvedCan I Convert Two 4pin Molex Connectors to 6pin PCIe to power AMD HD7870 Forum
- SolvedPcie cable won't connect all the way into Gpu Forum
- SolvedLooking to convert this cable on the power supply. Forum
- SolvedMultiple devices to one SATA power cable Forum
- SolvedHow to convert sata hdd to usb external hdd without dc power supply Forum
- SolvedIs it safe for the sata cable to be touching the PCB side of the GPU? Forum
- Solveddual SATA power to 8pin PCIE Forum
- SolvedConnect floppy power cable to PCIe board??? Forum
- SolvedGeforce GTX 780 power supply with a single PCI-E 8 pin cable? Forum
- Solvedsata to data power cable Forum
- SolvedPC Won't Power On With PCIE Cables Plugged Into Video Card Forum
- SolvedDaisy Chained PCIE power cable on PSU Forum
- SolvedCan a sata cable power both the optical drive and a hdd Forum
- SolvedPCI-E Power Cable Forum
- SolvedPower SATA cable and SSD issue Forum
- More resources
Read discussions in other Components categories
