Tom's Hardware > Forum > Mobility Networks > Cingular > Problem sending Pictures to an AT&T phone.
Forum Mobility Networks : Cingular - Problem sending Pictures to an AT&T phone.
Archived from groups: alt.cellular.cingular (More info?)
I just got a Go Phone plan on my unlocked Sony Ericsson T226.
My problem is- when I try to send data files, such as pictures, or
sounds, it comes up with "The User ID and Password are incorrect."
I'm not sure if I have to set up a new mMode profile, ect. I've signed
up on the Media services website. Tech support couldn't figure it out.
I'm hoping you guys know what's up (They kinda seem like idiots.)
Kato13
Cell Phone Forums: http://cellphoneforums.net
View this thread: http://cellphoneforums.net/t178985.html
Sponsored Links
check www.howardforums.com. You most likely will need to set up the
WAP settings and MMS settings. If you signed up after 6/1/05 you will
need to set the WAP and MMS to the Cingular settings. Before 6/1/05
then you will need the mMode & MMS settings.
Reply to Anonymous
Where exactly on the site would it be? You're correct btw, that's what
I assumed I had to do.
Kato13
Reply to Anonymous
If you haven't subscribed to howardforums.com then do that 1st. It's
free to register. Once registered and logged in then use the search
button at the top of the page. Look for "cingular wap settings" you
can also check in the Sony Ericsson forum and search as well for more
details on setting up the T226.
Reply to Anonymous
There are 586 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
