Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > PLEASE HELP!!! Sound Question on XP
Forum Windows XP : Windows XP General Discussion - PLEASE HELP!!! Sound Question on XP
Weirdest thing!! I have my Sound Scheme set to no Sound, but I still hear it!!
The only sounds that it makes are Minimize, Maximize and Close. How can I get rid of these sounds too?
Sponsored Links
Try disabling them in Control Panel==>Sounds and Audio Devices
-- Ah sh*t! sys64738 --
Reply to Mavicator
That's where I did it. It says no sound already. And other ideas?
Reply to Anonymous
You could go into audio properties and mute your system volume..
Reply to jktzweiss
But that's the whole point. I WANT to listen to music and such without hearing that sound each time I close a window.
Reply to Anonymous
Did you actually use the sound scheme "No Sounds"? If so, then choose this scheme, scroll down and disable any sounds that have been mysteriously activated, then Save As "No Sounds" again.
Please check out <A HREF="http://www.geocities.com/btvillarin" target="_new">My Website</A> last updated 12/11/01
Reply to btvillarin
I've already done that.
Reply to Anonymous
Why don't you create your own sound scheme, specify that no sounds should be played, and give the scheme a name, like your screen name. Afterwards, either move or delete the .wav files from the media folder so your computer can't find them.
Toejam31
<font color=red>My Rig:</font color=red> <A HREF="http://www.anandtech.com/mysystemrig.html?rigid=6847" target="_new">http://www.anandtech.com/mysystemrig.html?rigid=6847</A>
____________________________________________________
<font color=purple>"Procrastination on your part does not constitute an emergency on my part."</font color=purple>
Reply to Toejam31
Where are the wav files located?
Reply to Anonymous
I think <A HREF="http://www.tweakxp.com" target="_new">TweakXP</A> has something on this. Might be a registry key or something. You might want to give them a look.
-=Cpl. Tunnel, IT Special Forces. Putting the "combat" back in computers.=-
Reply to cpl_tunnel
There are 875 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 demondrumer won the Freshman badge
  • 01:00 tehue won the Freshman badge
  • 12:11 mi1ez won the Watchman badge
  • 01:00 sighQ2 won the Freshman badge
  • 09:06 ulysses35 won the CPUs badge
  • 01:00 fleeb won the Freshman badge
  • 01:00 jaymoney61 won the Freshman badge
  • 07:06 amdfangirl won the Watchman badge
  • 01:00 benw won the Freshman badge
  • 01:00 anmjoven won the Freshman badge
