RE: New Build Issue/ Switched On The Off Then On
Hi, I have just joined the forum.
I put together a computer about 2 days ago. Everything seems to be ok apart from this. When i start the computer it stays on for about 3 seconds everything loads up ok and then about 3 seconds it switches off. It will the switch back on again and stay on until i shut it down. Any help would be much appreicated.
My System
Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor -
EVGA GeForce GTX 570 HD 1280MB GDDR5 PCI-Express Graphics Card
Corsair Cooling Air Series A50 Performance CPU Cooler
Sony Optical 24x DVD Writer, AD-5280S-0B, SATA, Black, OEM
650W Corsair TX650 V2 ATX2.3 SLI/Crossfire Compliant Power Supply
8GB G.Skill RipJawsX (2x4GB) DDR3 1600MHz 8-8-8-24 Dual Channel Kit - F3-12800CL8D-8GBXM
ASUS P8P67 Intel P67 (REV B3) Socket 1155 DDR3 PCI-Express Motherboard
500GB Seagate Barracuda ST500DM002 3.5" SATA III Hard Drive
Thanks Chris
1 answer Last reply
More about build issue switched
  1. I had a similar issue with my new build, turned out to be the power supply couldn't handle the startup load, I would return that PSU and get another because it should be big enough.
    Just my 2 cents do with it what you will.
Homebuilt Systems
