Solved
$1000 The perfect best sandy bridge build please help
I was recomended to go with Intel build, heres my setup now.....
memory http://www.newegg.com/Product/Product.aspx?Item=N82E16820231314
GPU http://www.newegg.com/Product/Product.aspx?Item=N82E16814127578
motherboard http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=93425&CatId=6978&inbeta=Y
PSU http://www.newegg.com/Product/Product.aspx?Item=N82E16817182072
CPU http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072
case http://www.newegg.com/Product/Product.aspx?Item=N82E16811119197&nm_mc=OTC-Froogle&cm_mmc=OTC-Froogle-_-Cases+%28Computer+Cases+-+ATX+Form%29-_-Cooler+Master-_-11119197
ssd http://www.tigerdirect.com/applications/searchtools/item-details.asp?EdpNo=365474&SRCCODE=GOOGLEBASE&cm_mmc_o=VRqCjC7BBTkwCjCECjCE
$140/110-MSI P67A-GD53 B3 Intel P67 Motherboard - ATX, Socket H2 (LGA1155), Intel P67 Express, DDR3 2133MHz (O.C.), SATA 6.0 Gb/s, Gigabit LAN, CrossFire/SLI Ready, USB 3.0
$265-MSI N560GTX-Ti Hawk GeForce GTX 560 Ti (Fermi) 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
$215-Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) 4 x 256KB L2 Cache 6MB L3 Cache LGA 1155 95W Quad-Core Desktop Processor BX80623I52500K
$120-OCZ Vertex Series OCZSSD2-1VTX30GXXX 2.5" 30GB SATA II MLC Internal Solid State Drive (SSD)
$45-G.SKILL Sniper Low Voltage Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBSR2
$90-COOLER MASTER HAF 922 RC-922M-KKN1-GP Black Steel + Plastic and Mesh Bezel ATX Mid Tower Computer Case
$126/90-XFX Core Edition PRO850W (P1-850S-NLB9) 850W ATX12V / EPS12V SLI Certified CrossFire Ready 80 PLUS BRONZE Certified Active PFC Power Supply
935 after rebate
1005 before rebate
ME>>>:) After making a perfect xmas sandy bridge, lol
About the 60gb ssd im going to use that for speed not storage i have a 320gb sata for storage.
all help and opinions are welcome, thanks.
ok edited the this as of 7:47pm 11/13/11
Please Post links, THANK YOU Also if u havent noticed WILL select best answer if I like your Post, so If you benifit from it dont be lazy...
7 answers Last reply Best Answer
More about 1000 perfect sandy bridge build help
  1. Get a Z68 Motherboard I findthem to be more versatile than a P67
    Besides that I cant really say much about the PSU brand never tried them, and everything else looks great. You made a fine well balanced computer that will perform greatly for you. Whats your current monitor resolution?
  2. Best answer
    Isn't sacrificing the case for a 570 the better option like I laid out?
    Anyways, ymmv.
  3. SSDs are more beneficial for speed than the CPU and RAM combined, how can anyone not like SSD drives,lol. They are not optional for serious computer users.
  4. thanks to all the people that posted in helping me build this rig. If i could I would + everyones karma or point for there account.
    Please keep posting with links, ty.
    P.S. I chose the case because its very similar and its red with great cooling , I agree your case is nice though.
    And now hopefully I get these at a bargan price on black friday :).
    Still no found a best answer bty (by the way)
    And if you find a better motherboard by all means post it.
    The reason I'm going with that motherboard, is for the main reasons
    *Cheapest
    *2 Pci slots for wifi and soundcard
    *MSI is a good brand
    *ATX sized
    If you can find a better motherboard with thos specs listed above by all means, POST.
    I'm trying to perfect this sandy bridge.
  5. +1 for the 570 the pirate proposes
  6. Best answer selected by almightynsx.
  7. Highest, but im just basing my decision on most power and features for the least expensive.
    Im going to play games on wii emulator.
New Build Systems Product
