I just purchased a new AsRock Extreme6 and have an existing Windows 7 partition on a Samsung 830 256GB SSD. I want to get it to boot into my old version of Win 7 without starting from scratch. How do I do this? When I select the Samsung 830 as my boot device it gives me the message:
"Windows failed to start A recent hardware or software change might be the cause. To fix the problem...."
the error code is: 0xc0000225
everything I've tried so far doesn't seem to work.
I installed a installation disc (I dont have my original) to a flash drive and that booted up fine, but when I run the system repair it doesn't seem to do anything. Also the install disc doesn't seem to detect that I have windows 7 installed on my SSD. Is there a way to get it to detect this so I can get my system running again?
Thanks.
Thanks.
