Mic issue, need sound card?
I recently got a new computer case and I noticed that my headset that has audio jacks the mic doesn't seem to work. The sound works fine, the mic doesn't. When I plug in a headset that plugs into a usb port it works just fine. However when I switch over to the headset that uses the audio jacks the mic doesn't work. I go into the hardware > sound settings and it says Mic is unavailable under the recording tab. Does this mean I don't have a sound card?
Specs:
Intel i-5 2400
nvidia gtx 560
ATX Biostar H61MGC Mobo
6GB Ram
CoolerMaster 430 Elite Case
4 answers Last reply
More about issue sound card
  1. The headset that uses USB is a soud device on its own so it will work either way.
    As for the other one, are you plugging the jacks on the case's front panel or on the motherboard?
  2. You will have a soundcard, but it maybe a built in one (which is fine). Sounds like you have a headset with a green jack and a pink jack, once it is plugged in you will need to configure it in windows sound options.
    You may also have a control panel for your soundcard on the task bar near the windows clock.
    I've tried both, plugging it into the motherboard and the jacks on the front panel. When plugged into the jacks in the front panel, I get bad static.
    Probably a silly question, but should I have the AC 97, or the HD Audio cable plugged in on the motherboard?
    Not a silly question at all. The pinout is different between them.
    http://www.sevenforums.com/sound-audio/44491-ac97-hd-audio-front-panel-layouts.html
    You should check your mobo's manual for that.
    Did you install the soundcard's own software or just left it as Windows recognized it? I have a mobo with 6 audio jacks and because they are all auto-sensing, there is no particular jack just for the mic. They can all be either inputs or outputs. Maybe they're not recognized correctly by Windows.
Sound Cards Gaming Headsets Components
