Good evening Tom's,
So I have the following: i5 2400, PNY Optima 8 GB DDR3-1033 CL9 RAM (2x4 GB), Palit NE5TX460FHD79 GeForce GTX 460 768MB, ECS P67H2-A3 motherboard, and a Thermaltake TR2 W0388RU 600W PSU, and a Creative Sound Blaster Audigy SE PCI Card.
The graphics card just basically goes out at times when I'm playing a game, although I've seen it also go out once when I was playing music and browsing the web at the same time while a TV was also plugged in in dual monitor mode. The reason why I know its the graphics card going out is because:
1) The motherboard beep codes that happen (1 long, 6 short) afterwards point to a "vga adapter not found". Interestingly enough, the computer reboots (or at least I think it does since the fan speeds increase as if its rebooting) and during reboot it produces those beeps and has no video. However, when turning the computer back off and on, it boots normally and the beeps disappear. I suspect maybe there's some sort of protection built into the power supply cutting off power to the graphics card? Not sure.
2) The BSOD codes that show up in the improper shutdown message from windows once I boot into it indicates a graphics card issue.
Now I don't know if this is related or coincidence, but its also been happening after I installed a cpu cooler with a screw on bracket instead of the push pins.
Consistently, it happens during roughly 15 minutes of playing Sonic Generations. I wonder if its a bad card, bad drivers, who knows. I was also reading up articles on +12V rails, and I do know this PSU has a +12V1 32 amp rail and then a +12V2 24 amp rail. What I don't know is, could it be possibly be a rail issue if say the rails are getting overloaded? This actually didn't happen with Gears of War or Starcraft II, although I haven't tested those games since October.
If anyone has insight let me know. I'm thinking of RMA'ing the card, but I also want to make sure it isn't a different issue before I do that (aka, I wonder if its the rail requirement). Theres only a handful of Newegg reviews, some people complaining of same issue.
EDIT: If anyone's wondering if it has to do with the fan speed of the GPU, I tried it once with a 100% fan speed and still crashed on Sonic Generations.
