MB: Asrock Z77 Extreme 4 http://www.newegg.com/Product/Prod [...] 6813157293
CPU i5 3570k http://www.newegg.com/Product/Prod [...] 19116504RA
RAM:G.SKILL Sniper 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) http://www.newegg.com/Product/Prod [...] 6820231416
PSU: CORSAIR HX Series HX750 http://www.newegg.com/Product/Prod [...] 6817139010
Cooler: COOLER MASTER Hyper 212 http://www.newegg.com/Product/Prod [...] 6835103065
Case: Rosewill THOR V2-White Edition (excited about this) http://www.newegg.com/Product/Prod [...] 6811147158
Video Card: HIS Radeon 5850
SDD: samsung 840 pro 128gb
Just got my system together booted up great during updates and driver installs. A window popped up saying my copy of windows might not be genuine, this was also during a bunch of windows updates. windows turned black {no normal desktop} reset and now im stuck on the ASROCK logo everything turns on keyboard, mouse, fans, leds, cd drive. Then it resets and keep cycling over and over. Ive hit the CMOS reset button and it will boot to the bios and then it will all happen again. Ive set it at default setting and even switched my HDD back in with the same results. On the mobo it gives me these numbers in sequence they are as follows:
4F 62 99 64 A2
Any help would be much appreciated! thank you
4F 62 99 64 A2
