Sign-in / Sign-up
Display solution in motherbord
  • Chipsets
  • Motherboards
  • Displays
December 20, 2012 12:30:06 PM
Hello,
More about : display solution motherbord
a c 717 V Motherboard
December 20, 2012 12:38:46 PM
Welcome to Tom's Forum! :)
Hello?
It entirely depends on the 'MOBO' and on 'newer' sockets the CPU. Examples:
Using an Intel LGA 1155:
- Supports HDMI with max. resolution 1920 x 1200 @ 60 Hz
- Supports DVI with max. resolution 1920 x 1200 @ 60 Hz
- Supports DisplayPort with max. resolution 2560 x 1600 @ 60 Hz
- Supports Thunderbolt with max. resolution 2560 x 1600 @ 60 Hz
Using an AMD FM2:
- Supports HDMI with max. resolution 1920 x 1080 @ 60 Hz
- Supports DVI with max. resolution 2560 x 1600 @ 60 Hz
- Supports RGB with max. resolution 1920 x 1600 @ 60 Hz
- Supports DisplayPort with max. resolution 4096 x 2160 @ 60 Hz
m
l
