I have just purchased a phantom 410 for my new pc build but only 6 of the 9 motherboard standofs work. I tried that bad screws in every screwpoint but they only seem to go in half way before getting stuck. Will I be fine with only 6 standoffs on my atx z77 D3h gigabyte board? I was thinking having the screws arranged like this i it okay?
X 0X
0 XX
X 0X
Where X is a standof and 0 is no standof and thr top left X is the top of the case next to the I/O shield. Also if this helps I will have a hyper 212, 2 sticks of lp corsair ram and an msi 7850 (metal cooler). Any ways of making screws screw and do they need to be screwed in all the way because they are secure when at half-> 3/4 of the way down thx! Also I wont have time to get new standofs before I must build
X 0X
0 XX
X 0X
