Hello everyone!
I need a bit of advice.
I started building a new gaming PC, A8-3870k Quad Core CPU 3.0ghz, 8gb ram and ATI Radeon HD 6970, and I'm not sure if I should add extra fans to cool it down, the case I currently have is CoolerMaster Elite 310 Blue Case. A friend told me that I shouldn't be so worried about the cooling, that it won't overheat, but looking at the case you can straight away tell that it is not for "hardcore" gaming.
If any of you could tell me if I should consider adding any extra fans to cool it down, I would really appriciate it!
Thanks for any help, and sorry if its in the wrong sub category!
