Nzxt phantom 410 and asrock 970 extreme3 front usb connectors?
  • Motherboards
  • ASrock
  • USB
December 20, 2012 10:08:07 PM
My nzxt phantom 410 came with a long cord ending with a blue connector (I believe its usb 3.0) and I can't find a place on the motherboard to plug it in. Any advice? The motherboard manual doesn't really say anything about it.
More about : nzxt phantom 410 asrock 970 extreme3 front usb connectors
Anonymous
a b V Motherboard
December 21, 2012 7:35:11 AM
yeah your mother motherboard doesnt have a usb 3.0 header
if you want more usb 3.0 and want to use those ports as usb 3.0 you can get this. it add 2 usb 3.0 to the rear and has a 20 pin header
http://www.amazon.com/Uspeed-PCI-E-Express-20-pin-Conne...
m
l
