I am totally new to forums, so please forgive me if this is not the correct place to post this question.
I recently upgraded my Core 2 Duo machine with a new HIS HD 5750 Iceq+ 1GB GDDR5 graphics card and a Cooler Master eXtreme Power Plus 500W PSU (http://www.coolermaster.com/product....roduct_id=3738).
Reading this particular GPU's review on, and about how good the Iceq cooler is, I decided to monitor my GPU's temperature while gaming. So I was playing Crysis 2 at max settings on 1600x900 (native) resolution, when I saw that my card was topping at 81c at 100% load! The exact same card that was reviewed, it reached a max 68c on full load. Also, when idle, the reviewed card remained at 36c while mine idles at 44c. After going through various forums, I have learned that 81c at full load is normal for GPUs, but given that mine has an Iceq cooler, shouldn't it be lower? Do I need to worry or I am just over-reacting? I have the latest Catalyst drivers (11.8).
My Specs:
Windows 7 Ultimate 64bit
Intel Core 2 Duo E7300 @ 2.66 GHz (stock)
Intel DG43NB Motherboard
4GB DDR2 RAM
HIS HD 5750 IceQ+ 1GB GDDR5 (stock)
Cooler Master eXtreme Power Plus 500W (http://www.coolermaster.com/product....roduct_id=3738)
Cooler Master Elite 334 Chassis (http://www.coolermaster.com/product.php?product_id=4253)
P.S:
Room temperature is roughly 32-35C. Also, I have made it sure that dust is not the issue, since I regularly check my system for dust.
My Specs:
4GB DDR2 RAM
P.S:
