Sign-in / Sign-up
Solved
Optimal case air flow
  • Power Supplies
  • Cases
  • CPUs
  • Components
Last response: in Components
February 16, 2012 4:51:58 AM
i have an old apevia mid tower case case i got awhile go.
4 80mm fans and 1 120mm
i was thinking 2 bottom front 80mms be intake blows over my harddrive
side 80mm over cpu intake, the side fan is right over my cpu fan
top 80mm out take
120mm out take
iam buying new fans without annoying leds and i was just wanting to optimize my air flow.
More about : optimal case air flow
a b à CPUs
February 16, 2012 7:22:06 AM
Are there any empty fan grills in the top of the case?, if not i highly recommend cutting 1 out for top case ventilation to maximize heat dissipation.
m
l
a b ) Power supply
a b à CPUs
February 16, 2012 7:27:08 AM
"Are there any empty fan grills in the top of the case?"
It says he has one right in his post.
m
l
a b à CPUs
a b ) Power supply
February 16, 2012 9:12:45 AM
top 80mm out take
120mm out take
Pictures speak a thousand words my friend, take some pics of your PC including all sides top and bottom and rear and front and a good one of the inside, post them here and we will be more able to help you.
m
l
a b à CPUs
a b ) Power supply
February 16, 2012 9:13:44 AM
Also post Hardware specs of your PC and monitor, what you use it for, oh and do you have a dremel?
m
l
February 16, 2012 9:33:09 AM
none of these posts are relevant to my interests or a tad helpful
here is a picture to help
m
l
a b à CPUs
a b ) Power supply
February 16, 2012 9:36:27 AM
http://i.imgur.com/E9Ygn.png
Then try doing as you asked if you wish to resolve your problem, instead of pointlessly whinging.
m
l
Best solution
a c 159 ) Power supply
a b à CPUs
February 16, 2012 4:24:57 PM
top 80mm out take
120mm out take
In general:
Front = intake
top/rear = exhaust
side = intake (normally side fans are aligned over the GPU and this provides extra cool air)
To answer your question...I think that your planned placement and intake/exhaust plan is good.
February 17, 2012 3:31:40 AM
Best answer selected by choobert.
m
l
