Asrock z68 extreme3 help
December 22, 2012 1:07:30 AM
Hello everyone, I have an asrock z68 extreme3 gen3 and a i52500k i need some help, I don't know if i want to overclock my system right now, but i would like help with stopping my CPU from fluctuating.
In CPU-Z my core speed is 1600.Mhz is there a way that i can turn the phase off? so its constantly at 3.30Ghz
if so can somebody help me with the settings in my bios? i've turned Phase off in Asrock extreme tuner and nothing happened if someone can help me it would be greatly appreciated.
More about : asrock z68 extreme3
a b V Motherboard
a b à CPUs
December 22, 2012 2:26:29 AM
Look in the BIOS in the OC Tweaker Screen. You should disable the SpeedStep Technology option. See if this helps.
m
l
December 22, 2012 2:39:36 AM
i tried that did not work.
m
l
