I need some help with my new build.
Any changes I need to do? Are their any recommendations?
Please note I live in Canada and all I prefer to get things from Newegg.CA not .com
Over clocking: CPU only (I might try GPU and RAM one day though)
Use: Gaming, Web browsing
Games: TF2, SC2, Dragon age and maybe skyrim (But I'm okay with playing on low)
Purchase date: Ill be buying this after Christmas.
CPU: http://www.newegg.ca/Product/Product.aspx?Item=N82E16819115072
MOBO: http://www.newegg.ca/Product/Product.aspx?Item=N82E16813130583
RAM: http://www.newegg.ca/Product/Product.aspx?Item=N82E16820231314
GPU: http://www.newegg.ca/Product/Product.aspx?Item=N82E16814102908
Monitor: http://www.newegg.ca/Product/Product.aspx?Item=N82E16824236130
OS: http://www.newegg.ca/Product/Product.aspx?Item=N82E16832116986
Mouse + Keyboard: http://www.newegg.ca/Product/Product.aspx?Item=N82E16823126197
PSU: http://www.newegg.ca/Product/Product.aspx?Item=N82E16817139028
Wireless adapter: http://www.newegg.ca/Product/Product.aspx?Item=N82E16833166060
Case: http://www.newegg.ca/Product/Product.aspx?Item=N82E16811119196
DVD Drive: http://www.newegg.ca/Product/Product.aspx?Item=N82E16827106289
HDD: Ill wait till the prices arn't crazy. If they don't go down soon I may go with Ivy Bridge and Radeon 7xxx instead.
Grand Total: $1,172.37
It took a lot of little changes to get everything to work in the budget and id hate to have to go past $1200 but if its worth it and is the PSU sufficient?
