I've owned my Antec 300 for over a year now and absolutely love it. It will probably be the only case i ever use so long as it’s in production. As things go, and time passes it’s time for an upgrade...
Prior to the upgrade I had my CPU fan blowing out the top of my case through the 140MM fan. Thinking in retrospect probably it wasn’t the best solution as it was drawing heat from my GPU. That’s since changed because my new RAM didn't quite fit with that heatsink configuration. It's now blowing out the back.
That’s the background information... Here’s where I would like to use the collective and creative thoughts of the Tom's community to brainstorm possible some options. If it’s even possible.
Basically in the bottom two 5.25 drive bays I want to mount 2 80MM fans side by side. The mesh bay covers have a piece of hard plastic behind them which I have removed. I'm trying to brain storm some mounting solutions in which the fans are still easily accessible, not wobbling (noise concerns), and maintain the sleek look of the case (IE not screwing them into the mesh)
I'm also going to be buying some fan filters to try and keep the case as dust free as possible. Which also needs to be somewhat accessible / removable?
The thought of this is having the 2 80MM fans blowing into the CPU fan, then straight out the back of the case.
Thanks for the input.
________________________
Antec Three Hundred
EVGA P55 Intel ATX Intel Motherboard
Intel Core i5-750 Lynnfield 2.66GHz
Corsair A70 CPU Cooler
Patriot G Series ‘Sector 5’ Edition 4GB DDR31600
SAPPHIRE Radeon HD 6870 1GB
Antec Three Hundred
