PowerColor 4870x2 PROBLEMS!
G
Guest
Guest
Hi. I'm new here so be nice, thank you. I recently bought a new Powercolor 4870x2. I sold my old card, which was an anus gtx 465. I plugged it in and first I got some red led lights at the back of the card. After trying in some hours the led light are now gone. I have plugged in the 6pin and the 8pin connectors. The problem is that there aren's any display on my monitor. I use an AXP 850WATT psu with quad 12v rails.
Here is my entire system:
Mobo: Msi gf615m-p33 v2
Ram: 4gb 1333mhz
Hard disk: 500gb 7200rpm
cpu: amd phenom ii x4 955 @ 3.2 Ghz
psu: Axp 850w (720-900) quad 12v rails
I also have a fan controller, 3 led fans and 2 high performance fans.
I NEED HELP! Btw my system is working, I have tried other graphic cards and they work.
Sorry my bad English, I'm from Norway and only 15 years old. Hope you understand.
G
Guest
Guest
No I haven't, but it's brand new
Rizlla
403
As you said you have already tried other cards in your system and they worked, so I would suggest that would be the next step or unless you are just connecting the card incorrect. Make sure it clips in properly into the PCI-E slot.
G
Guest
Guest
I have tried everything?
