I'm building a new computer and I'm in a bit of a bind. I'm not a gamer, nor am I interested in HT. Nothing in the reviews nor the manufacturers specifications seem to let me know what would be best for my needs.
So far I'm looking at:
CPU - AMD X4 630
MB - Asus M4A88T-M LE
RAM - Samsung 4G stick PC3-10600 1,333ghz (upgrade to 8 later)
PSU - Antec VO550P 550W
This is really all my current budget will allow and I'm pretty confident this will do except for the GPU...I'm at a loss. I could cut down on the CPU I suppose, but the 10 dollar difference for the x3 455 is only a couple of beers...
I often edit 60MB TIFF files (5000X3500) and RAW files either from my DSLR or my Nikon Cool Scan V ED. I also design houses and whatnot from time to time and plan to be running Autodesk for some small home projects. Autodesk recommends a minimum AMD 3GHz dual core 64 bit 2 GB RAM and 1,024 X 768 display resolution with true color. So I think I'm more than good so far but I really hate getting done to some fine window detail or something and finding my computer sluggish. It can make drawing a simple line hard and frustrating. It also makes it tough for me to open several graphic files so that I can compare them.
I have read countless reviews and can't pick if I need a 125$ unit or a 50$ unit.
Gigabyte HD 5750 UDV D5 1G silent - 125$
Gigabyte HD 5570 HDMI D3 1G - 104$
Gigabyte GT 240 UDV HDMI D3 1G - 101$
Asus HD 5670 EAH 5670 D3 1G - 99$
Gigabyte HD 5670 UD2 D3 1G - 80$
Sapphire HD 5570 HM D3 1G - 72$
Asus GT 520 1G silent - 70$
Asus GT 220 ENGT220 D2 1G - 70$
Gigabyte GT 520 D3 1G - 60$
Asus G 210 EN210 V2 D3 Silent 1G - 50$
I've selected only cards with a 1GB cache because it was suggested on a photographic web site (that had little else worth adding unfortunately)
I also want a card that runs cool and uses as little energy as possible. Obviously I'd love to save my pennies for beer and buy the little, silent cool running Asus G210 or the Gigabyte GT520. If however my need for 2 monitors (a 22 and a 19 inch) of work space with large images and design drawings (while listening to tunes of course) then I will be forced to bite the bullet and buy either the Gigabyte GT240 or HD5570...then I'll get to play some games too I suppose.
Any help would be very helpful. I hope to keep this rig running for the next 5 years.
CPU - AMD X4 630
