Win 7 64 Bit, GTX 560 Driver Display Adapter problem
Welchyy
4
I have recently built a new PC from scratch, currently I am experiencing an issue which I believe to be a display driver issue.
When I attempt to install my graphics driver (Nvidia Geforce GTX 560) and attempt to reboot my PC it proceeds past the POST/Asus Logo screen and onto the "Loading Windows" screen, after the logo appears and finishes loading, instead of it moving on to my login screen it hangs on a blank BLACK screen with just my mouse pointer visible.
I have tried running the repair tool on the windows 7 disc, and in safe mode with no avail it tells me nothing is wrong. I attempted to run the start up repair and that also says nothing is wrong.
I have attempted to clear out all the stock drivers via driver sweeper, and clean the registry with ccleaner, downloaded the newest mhql to my desktop and attempted to install it in safemode, though this didn't work either.
Is this a common problem? Anyone have any ideas? been troubleshooting for a week now, can't find much online.
OS: Windows 7 64bit Home Premium
CPU: Intel i7 2600k 3.4ghz
MOBO: P8z68-v PRO
Graphics Card: EVGA Nvidia Geforce GTX 560
Memory : 8GB DDR3 1333mhz Ram
PSU: 950 Watt
500g HD
Dxdiag
Time of this report: 9/18/2011, 21:25:10
Machine name: xxx-PC
Operating System: Windows 7 Home Premium 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.110622-1506)
Language: English (Regional Setting: English)
System Manufacturer: System manufacturer
System Model: System Product Name
BIOS: BIOS Date: 02/05/10 19:13:52 Ver: 08.00.10
Processor: Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz (8 CPUs), ~3.4GHz
Memory: 8192MB RAM
Available OS Memory: 8168MB RAM
Page File: 1419MB used, 14915MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Standard VGA Graphics Adapter
Manufacturer: NVIDIA
Chip type: NVIDIA
DAC type: 8 bit
Device Key: Enum\PCI\VEN_10DE&DEV_1201&SUBSYS_14603842&REV_A1
Display Memory: n/a
Dedicated Memory: n/a
Shared Memory: n/a
Current Mode: 1600 x 1200 (32 bit) (1Hz)
Monitor Name: Generic PnP Monitor
Monitor Model:
Monitor Id:
Native Mode:
Output Type:
Driver Name: nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um
Driver File Version: 8.17.0012.7533 (English)
Driver Version: 8.17.12.7533
DDI Version: unknown
Driver Model: unknown
Driver Attributes: Final Retail
Driver Date/Size: 5/21/2011 06:01:00, 15223912 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B71E3E-5141-11CF-F31B-D0290FC2CB35}
Vendor ID: 0x10DE
Device ID: 0x1201
SubSys ID: 0x14603842
Revision ID: 0x00A1
Driver Strong Name: Unknown
Rank Of Driver: Unknown
Video Accel:
Deinterlace Caps: n/a
D3D9 Overlay: n/a
DXVA-HD: n/a
DDraw Status: Not Available
D3D Status: Not Available
AGP Status: Not Available
isamuelson
Have you connected all the PCIe power connectors to your video card? I have a Gigabyte 560 SOC card and it requires two 6-pin PCIe power connectors.
You definitely have the power supply for it.
If that is the case, ensure the GPU is seated firmly in the PCIe slot. Otherwise, get another GPU (if you have one) and use that to see if things work.
If another GPU works, then it might mean you have a bad GPU card.
