Viewing burned VCD in DVD player,problem-pl. help!
G
Guest
Guest
I have used P4 processor, Sony CDRW and Adaptec EZ CD creator to create VCD (MPEG1) from Panasonic digital camcorder (DV). I did not have any problem in creating this VCD.
However, I am unable to view this VCD in Panasonic A320 DVD player. But I could able to view VCD using any computer CD-ROM. I tried creating VCD with both CD-R and CD-RW dics. Both of them failed in my DVD player.
How could I make a VCD which can be read by a DVD player?.
I appreciate any help.
Arrow
Splendid
Dec 31, 2007
4,123
What do you mean by can't view it? Does it not even show anything but a black screen? Does the player not recognize it as a VCD? Does it run but just flickers so much that it's unable to be viewed?
Rob
Please visit <b><A HREF="http://www.ncix.com/shop/index.cfm?affiliateid=319048" target="_new">http://www.ncix.com/shop/index.cfm?affiliateid=319048</A></b>
G
Guest
Guest
Hi Rob,
Thanks for the reply.
My DVD player doesn't recognize that there is VCD loaded. What should I do?.
Any help/suggestion appreciated.
- Tom.
Arrow
Splendid
Dec 31, 2007
4,123
Hi Tom,
The only thing that I can think of is to make sure that you're using their wizards to make the VCD. Make sure you select "video CD." Or you might want to try a different brand of CDR; sometimes that makes a difference too. I haven't experienced that problem, but have experienced problems due to NTSC/PAL incompatibilities, in which case it flickers.
Rob
