Solved
Asrock z68 extreme3 help
Hello everyone, I have an asrock z68 extreme3 gen3 and a i52500k i need some help, I don't know if i want to overclock my system right now, but i would like help with stopping my CPU from fluctuating.
In CPU-Z my core speed is 1600.Mhz is there a way that i can turn the phase off? so its constantly at 3.30Ghz
if so can somebody help me with the settings in my bios? i've turned Phase off in Asrock extreme tuner and nothing happened if someone can help me it would be greatly appreciated.
i've already turned intel speed step off and it didn't work, ive tried everything that i know of doing and it still remains the same.
6 answers Last reply Best Answer
More about asrock extreme3 help
  1. Best answer
    In CPU Configuration, try disabling the C1E setting too.
  2. Why do you want to run the processor always at full speed?
    If the system needs speed then it will automatically increase the frequency.
    Because i don't like it when it fluctuates id rather use all my resources to there potential .
  4. Do this
    In control panel > power options > change plan settings > change advanced power settings > processor power management > minimum power state
    Set it to 100%
    Apply.
  5. Best answer selected by dunsparth.
  6. Xttony said:
    Do this
    Set it to 100%
    Apply.
    i think i got it working now.
    Maybe i will overclock to 4.0 Ghz.
ASrock Overclocking CPUs Motherboards
