Help finding part for Lian-Li PC-Q08
Last response: in Components
February 17, 2012 9:31:34 AM
Hi,
I have a Lian-Li PC-Q08 case. It comes with a disk storage cage that can support 4 HDDs, and underneath that you can use either another disk storage cage, or a C-shaped section that supports the cage, but leaves room for a graphics card.
I have lost the C-shaped cage support, and would like to buy a replacement. Does anyone know where I could get one of these?
This (long) link shows the drive cage, the support I have, and on the right the support I am trying to get:
Thanks,
Paul
More about : finding part lian q08
a b ) Power supply
a b G Storage
February 17, 2012 9:57:14 AM
Write a mail to Lian-Li explaining the situation and they will immediately send you the misplaced part, maybe for a price, but usually they don't ask for anything if it's a minor issue.
February 17, 2012 9:58:46 AM
Thanks for the advice guys, I have written to them with their "contact us" form, so hopefully I'll get a response soon. I'll post back here when I do.
a b ) Power supply
a b G Storage
February 17, 2012 10:04:49 AM
Welcome, they are a very helpful bunch of chaps and will certainly hear you out.
