Solved
Possible to turn off power to a USB device?
I use a webcam occasionally and its a real resource hog. Plus you never know if a hacker has somehow controlled it, even briefly. There are other devices I'd like to be able to switch in and out without plugging in/out. I'd like to be able to cut the USB power to these specific devices somehow. Anybody know if this is possible? Can you turn off a USB port, even through the bios upon restarting? Presently using an Asus P5Q but that will be gone soon.
More about : turn power usb device
Best solution
Motherboard Authority
Go to device manager and disable the webcam. It is under the universal serial bus controller section(last).
Right click my computer > properties > device manager(left side) > universal serial bus controllers > webcam name
Right click on it and select disable.
When you want to reuse the webcam, use the same procedure and right click and select enable.
