G
Guest
Guest
Hey guys,
I finished building my new pc 5 hours ago, it contains:
Intel Core i7 3770k
Asrock Z77 Extreme 4
Corsair 500R
Corsair H100I
Corsair Vengeance 16gb ram kit
Sandisk 256gb ssd
Nvidia GTX 670 Windforce OC
Also this isnt the first pc i built.
Now as i was done building, i tried to start it up, fans start running, also cpu-fan, lights go on, but no beep from the mobo.
So i did the standard stuff, trying with only one ram installed, tried differenct ram slots, checked cables, took out the ssd, CMOS reset.
Nothing worked, so i took my mobo out of the case again and "breadborded"(i think its called like this) it, just cpu and cpu fan connected. It started up, but again no beep.
So i started searching in serveral forums on serveral pages, tried their solutions which were for ex :
-attaching keyboard via ps2
-attaching mouse
-attaching monitor
Nothing worked, and those 2 numbers on the mobo, dr debug, told me continuesly the error codes a2/a6/b4/d7.
Then i read somewhere that i need a newer bios version, but on asrock's page it says that my cpu is supported by the default bios version.
So now im wondering waht to do. Sadly got no old 1155 socket intel cpu lyin around to upgrade the bios version.
Contacting asrock so they send me a new bios battery would take pretty long time, since they have vacs currently.
All help is appreciated
Thanks in advance
Intel Core i7 3770k
Corsair 500R
Corsair H100I
Sandisk 256gb ssd
-attaching mouse
-attaching monitor
Thanks in advance
