I was wondering if it is possible to use eyefinity with a 32" middle HDTV, and two 21" monitors for the outside. I know its a huge difference in size, and that the resolution needs to remain the same on all three monitors ( right now i only have the 32" and one 21", both resolutions are at
1360 x 768) would it be worth buying another 21" for eyefinity or would it just not work right? thanks.
