Dremel tool works quite well, or a drill and jig saw with a fine blade. To keep from scratching or marring the case, use painters tape to cover the area completely you will be sawing, drilling, carving on. Pull the tape off when done.
what tool should i use? i noticed i do have a blow hole on the side and i cleaned the dust from my cpu heatsink which lowered my temps almost 10 degrees celcius while idle and under load. I'm just wondering out of curiosity now. Thank you.
