New College Gaming System Help!!
Hey guys im setting up a new build for college and my primary use is gaming (duh) looking to keep it around the 1500 range and this is what i have so far:
Mobo: ASRock Z68 Pro 1155
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157263
CPU: i5 2500K Sandy
http://www.microcenter.com/single_product_results.phtml?product_id=0354589
Mem: Ripjaws X 8GB (2 x 4Gb) 1600
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231428
HD: 750gb WD Caviar Black
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136283&Tpk=WD7501AALS
Optical: Blu ray combo CD/DVD
http://www.newegg.com/Product/Product.aspx?Item=N82E16827151232
GPU: either GTX 570 SC or 580 not sure yet
Monitor: ASUS VS248H LED HDMI
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236153&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-RSSDailyDeals-_-na-_-na&AID=10521304&PID=4176827&SID=1fh79nr26c27f
PSU: Corsair 800g gaming
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=6382282&CatId=2534
So my questions are. For my gaming mainly should i stick with the Z68 Pro board or go with the X58 Gigabyte boards? Is there any difference between the 2? Also how easy is it to OC? Im fairly new when it comes to OCing so im not really sure how its done. Any help at all would be much appreciated!!
9 answers Last reply
More about college gaming system help
  1. Yes, the difference between X58 and Z68 is that the former doesn't support your CPU.
  2. Stick with Z68. Your 2500k won't fit in X58 mobo. You need fan for OC:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065
  3. i can change around some components like the cpu. I was just curious whether or not the X58 is better for gamers than the Z68
  4. No. Triple channel, 6 core and more PCIe lane does not give better gaming performance for your level of gaming need and cost more.
  5. So stick with the Z68? ok thanks
  6. Yup, go with the i5 ;)
  7. so whats the whole purpose of OCing and how do you even do it?
  8. The purpose is increased performance. The method you need to research yourself before attempting. Google is a nice service, you should try it :P
New Build Gaming College Systems Product
