Is this a PSU problem or something else?
Last response: in Components
So I've decided to build rebuild my PC. To do this I went with an I5 2400, 8 gigs of DDR3, and a new motherboard (an ASRock z68M/USB3 if that matters). I've kept my existing components like my Radeon 6870 HD videocard, 500 gig 7500 rpm HDD, and a DVD burner.
I've hooked up everything and have doubled checked the connections three times now. When I turn on the system, the fans spin, and lights come on, but the computer will not boot at all, the screen stays black. I've got a 500w PSU of unknown quality, but I'm leaning towards a lower end unit since it came with the case a few years ago.
I've also tried taking out my vidcard and using the onboard video, still nothing. I've never had this type of issue so I'm stumped. I'm down to 2 things. 1. Its a PSU issue, or 2. My mobo came DOA.
Just looking for more expert advice.
Thanks in advance.
More about : psu problem
What was the old system? If it is something that uses fairly little power then I'd blame your PSU but right now leaning toward a bad Motherboard/or the Motherboard isn't grounded.
So I went out and got a different PSU, a 600w, plugged it in, same problem. On a whim I pulled one of my ram sticks and it booted up. I tried the other stick solo and the system booted as well, but it will not boot with both sticks plugged in.
Ask the community
