Solved
Does asrock z77 pro3 motherboard require both 24 pin connector and 4 pin connect
  • ASrock
  • Connection
  • Motherboards
December 25, 2012 9:50:25 AM
Hello,
does asrock z77 pro3 motherboard require both 24 pin connector and 4 pin connector to start because my new build is not getting to POST
my system
i3 3220
asrockz77 pro 3 mobo
corsair 4 gb ram
wd 1tb hard disk
525w cooler master extreme2
More about : asrock z77 pro3 motherboard require pin connector pin connect
Best solution
a c 94 V Motherboard
December 25, 2012 10:13:44 AM
dude, you need 8pin cpu pin (4+4 actually) and 24 pin connected....
for core i3 less than 125 watt, it is safe to connect only 4pin cpu, but it wont work that way on some cases
525w cooler master extreme2 is old tech unreliable psu. afaik, CM was a bad psu maker in the past. but it is getting better atm. you might want to replace it with corsair or xfx if you have no other solution to power on you pc
