mark romero Honorable Feb 18, 2012 15 0 10,510 Feb 18, 2012 #1 Hello, i was wondering if my power supply will work for an EVGA GTX 570 i have a OCZ Modxtream pro 600 Watt PSUbut the +12v is only 25 Amps is that ok for my GTX 570? Thanks
Solution Rugger Feb 18, 2012 A OCZ ModXstream 600W has a combined 50A on the 12V rails, exceeds nVidia's recommendations, and should be more than sufficient to run your PC.
RealBeast Titan Moderator Sep 13, 2010 17,111 474 104,790 Feb 18, 2012 #2 That PSU has 2 25A 12V power rails, not just one. Your single GTX 570 is fine on that PSU. Here are some power draw tests on that card from Tom's: http://www.tomshardware.com/reviews/geforce-gtx-570-gf110-performance,2806-14.html Bottom line, it will easily handle that card x1. Upvote 0 Downvote
Rugger Splendid Jan 11, 2005 6,707 0 26,160 Feb 18, 2012 Solution #3 A OCZ ModXstream 600W has a combined 50A on the 12V rails, exceeds nVidia's recommendations, and should be more than sufficient to run your PC. Upvote 0 Downvote Solution
mark romero Honorable Feb 18, 2012 15 0 10,510 Feb 18, 2012 #4 Rugger : A OCZ ModXstream 600W has a combined 50A on the 12V rails, exceeds nVidia's recommendations, and should be more than sufficient to run your PC. oh wow haha im dumb i completely forgot that it's not a single rail thank you so much Upvote 0 Downvote
mark romero Honorable Feb 18, 2012 15 0 10,510 Feb 18, 2012 #5 Best answer selected by Mark Romero. Upvote 0 Downvote
mark romero Honorable Feb 18, 2012 15 0 10,510 Feb 18, 2012 #6 RealBeast : That PSU has 2 25A 12V power rails, not just one. Your single GTX 570 is fine on that PSU. Here are some power draw tests on that card from Tom's: http://www.tomshardware.com/reviews/geforce-gtx-570-gf110-performance,2806-14.html Bottom line, it will easily handle that card x1. oh and thank you too! Upvote 0 Downvote
Rugger Splendid Jan 11, 2005 6,707 0 26,160 Feb 18, 2012 #7 mark romero : oh wow haha im dumb i completely forgot that it's not a single rail thank you so much You're very welcome - enjoy! Upvote 0 Downvote
