Will radeon 6970 work with a 530w power supply
Last response: in Components
February 19, 2012 11:31:09 AM
i have just orderd radeon hd 6970 GPU and a 530w power supply i was planing on getting the radeon 6950 and that needed a 500w+ power supply and i 4 got to get a change it to a 550w and i can not cancel it intill monday i need to know if the 530w will be ok or not it has every thing i needapart from its 530w not 550w any help.
this is the power supply i am getting http://www.ebuyer.com/190751-be-quiet-530w-pure-power-p...
a b ) Power supply
February 19, 2012 11:55:35 AM
Depends on the rest of the system, as your GPU is not the only part that sucks up wattage. In general a solid 550w PSU would suffice if you don't do much to any overclocking etc.
February 19, 2012 12:16:15 PM
i have
i5 650 3.2ghz
60gb ssd
1t hdd
cd-rom
motherboard is code 0t568r from dell
i know is many the CPU and GPU that take up the wattage
a b ) Power supply
February 19, 2012 1:24:58 PM
blackd834 said:
i have
i5 650 3.2ghz
60gb ssd
1t hdd
cd-rom
A quality 550W PSU should be fine with that system and a 6970. I'd go with that Corsair 550W PSU jemm mentioned.
