Confusing video card problem Please help
  • Graphics Cards
  • Monitors
  • Graphics
September 22, 2011 9:52:36 AM
New 5850 upgrading from my 8800 gt
installed with no problems. turned the system on... monitor did nothing.. turned it off and on... no signal
(could hear windows sounds tho)
Tried both my vga to div converters and both of my vga cables with no success
plugged the 8800 back in and it started right up.
5850s stuffed.
Brought my whole system in to the local pc shop for them to test it and it was working on their monitor fine
They told me that it didn't go in the top dvi port but worked in the bottom one after restarting.... told me that they all ports should be working when i install the drivers ( is that all?)
Went home plugged it.... no signal as before...
:fou:  What should i try now ?
System
550 watt Aywun psu
Q6600
4g ddr2
please help!!
More about : confusing video card problem
September 22, 2011 10:06:30 AM
Have you swopped out the signal cable of your screen?
m
l
September 22, 2011 10:10:27 AM
What do you mean?Iv tried both vga cables i own?
m
l
September 22, 2011 10:15:11 AM
Did you uninstall the Nvidia drivers before starting your pc with the ATi card in?
m
l
September 22, 2011 10:22:04 AM
yes i did but like i said the shop got it going with my system there cables and monitor... but my cables and monitor only work with the 8800 and not the 5850 it doesn't make sense. Is there different types of vga to div converters? or any reason this would happen?
m
l
September 22, 2011 10:23:45 AM
the monitor is a 192E Philips 19" if that has any thing to do with it.
m
l
September 22, 2011 10:32:39 AM
Perhaps test with a different monitor to see if that is the problem.
m
l
September 22, 2011 10:40:10 AM
mmm okay i will try that. Would still like to know why its happening.. the monitors brand new. thanks for your help so far tho man. much appreciated
m
l
September 23, 2011 11:13:04 AM
tried it on the 40" still no joy. this sux
m
l
September 26, 2011 6:24:01 AM
Did you see it work at the local PC shop? Maybe they lied to you.
m
l
