Trying to build a new computer, help with parts!!
bfos33
17
Hi, I was wondering if these parts were compatible, I want to spend around 800-1000 if you know of any items that are cheaper but are just as good, let me know!!
Motherboard- http://www.newegg.com/Product/Product.aspx?Item=N82E16813131770
CPU- http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072
Heatsink- http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065
Case- http://www.newegg.com/Product/Product.aspx?Item=N82E16811517004
RAM- http://www.newegg.com/Product/Product.aspx?Item=N82E16820231311
Power Supply- http://www.newegg.com/Product/Product.aspx?Item=N82E16817341017
Optical Drive- http://www.newegg.com/Product/Product.aspx?Item=N82E16827106289
GPU- http://www.newegg.com/Product/Product.aspx?Item=N82E16814130571
I'm not getting a hard drive right now because of the shortage, I have a spare one in the computer I have now. If I'm missing any parts could you let me know and recommend what you think I should buy? Thank You!!
bfos33
17
I'd really like to stick with nvidia, can you recommend a card thats nvidia in the similar price range, maybe 20 or 30 dollars more, if there will be a substantial difference you think.
WTFO
63
A gtx 560 is around 200usd depending on when you plan on purchasing you could probably find it on sale. Cyber monday is just around the corner. IMO its worth the extra $
bfos33
17
How? it's nearly identical and on websites I'm checking it gets nearly the same fps as the 560ti
