I am looking to buy a hyper 212 plus cpu heatsink when I build my new gaming computer in a few weeks, and wanted to know what kind of fans I could replace the stock ones with. Can I use any 120mm fans?
Not sure those will work due to the bracket you have to attach to the fan. It may, but it looks like the screws are a bit offset, I could be wrong, if it lines up like a normal 120 mm fan, itll work.
I want to put on two fans picked out by my self because they are orange and that is the theme I am going for. Will any fan work as long as they are 120mm?
The airflow rating is good - very close to the stock fan. Overall cooling shouldn't be affected.
But I have doubts that the straight mounting brackets will fit that rounded Cougar ran. The brackets are the straight rails in the lower right side of the accessory pack parts.
Well from the looks of it, the brackets just go in between the fan and the heat sink it self. Therefore, as long as the holes line up, it should be okay.
