Asrock 970 Extreme 3 Sound Problem
Hi,
I've just installed win7 x64 and all the drivers and I have the problem that when I connect a headphone or any other speaker I get a buzzing sound and get the message that a jack connector was plugged in and out continously. I'm using the onboard sound. What can I do to make it work ?
3 answers Last reply
More about asrock extreme sound problem
  1. Look like there is a faulty sound port. You should rma the mobo or use via front panel and configure it via audio driver as line-out.
  2. The front panel has the same Issue. Are you sure its is a hw problem ?
  3. Try reinstalling sound driver. I thought it was a sound port issue. But now it looks like chip issue as front panel shows the same. If reinstalling driver dont solve your issue then RMA the mobo.
ASrock Connection Motherboards
