Water cooling went boom...
- SolvedPSU went Boom. Now what? Forum
- my psu went boom! Forum
- something went boom... possibly. Forum
- AND IT WENT BOOM Forum
- New psu went boom Forum
- PSU went BOOM Forum
- New PSU went boom! Forum
- Installed a new cpu and my pc went boom Forum
- SolvedWater went inside my laptop, what should I do? Forum
- SolvedWater cooling vs air cooling? Forum
- Solvedwater cooling r9 290s Forum
- SolvedWill a 140mm rad cpu water cooler not provide enough cooling on NZXT H440 (Mid-tower)? Forum
- SolvedMulti-path Water Cooling? Forum
- SolvedWater cooling r9 290x problems Forum
- SolvedWater cooling using Corsair H75 Forum
- SolvedWater Cooling Elite 110/120/130 Forum
- SolvedWater cooling fans Forum
- Solvedwater cooling bridge for as rock z77 extreme4 Forum
- Solvedmsi aspen (socket am2 ) Water cooling corsair H50 compatibility Forum
- SolvedWater cooling push-pull config, should the strong fans do the pushing or the pulling? Forum
- More resources
Read discussions in other Motherboards categories
what happened when it blew did the pc instantly shut down did it smoke etc. You can clean the motherboard and other components with some electronics cleaner or just pour rubbing alcohol over it and use a soft (paint) brush , just make sure it dries completely (either compressed air or overnight is a good rule or thumb ) Then plug it up with a air cooler and let'r rip best case it will work. Good luck...
