L Levistator Honorable Feb 19, 2012 1 0 10,510 Feb 20, 2012 #1 I need a basic sound card. nothing fancy just something to get the job done. am building my own computer on a budget so pls not too expensive.
house70 Splendid Apr 21, 2010 4,448 0 23,460 Feb 20, 2012 #2 Every mobo has a sound chip integrated in the southbridge on the mobo. It will do as well as a dedicated basic sound card. Will only need a dedicated card if you plan to do some serious audio encoding. Upvote 0 Downvote
davcon Judicious May 17, 2010 8,860 0 34,960 Feb 20, 2012 #3 ASUS XONAR_DG 5.1 http://www.newegg.com/Product/Product.aspx?Item=N82E16829132020 http://us.ncix.com/products/?sku=56330&vpn=XONAR%20DG&manufacture=ASUS http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=7040891&CatId=2769 http://www.amazon.com/ASUS-Channel-Sound-Card-XONAR_DG/dp/B0045JHJSS/ref=cm_cr_pr_product_top/177-8910809-2329148 Upvote 0 Downvote
